Problem solved.......................FINALLY!!!!!!!!!!!!
Found that when I disconnected the vacuum line at the intake plenum the RPM's went through the roof.......also found that the line had a pretty good amount of crud in it.........sprayed the line out with carb cleaner and reconnected.......I had previously cleaned out the "PCV" valves but not the lines themelves. dam thing runs like a brand new truck!!!!!!!
To all those out there experiencing lack of horsepower.......by all means, CHECK YOUR VACUUM LINES!!!!!!!
