Is it possible to change out the top serp pulley without releasing the tension on the tensioner? I put in a new EGR valve several months ago. So I replaced the belt and tensioner as welI. I had purchased a new Gates brand top pulley or idler wheel and had that to also install. But as I did the work, comparing the original with the Gates, I thought the OEM looks to be better quality, so I did not install the Gates one. Now it is squeaking, so I wish I had put it in when I had the chance.
But I was just hoping it can be done from the top, without releasing the tension. Possible? I doubt it, but hoping.
