1 - 3 of 3 Posts
Josh
ok so i have heard a couple people installing the comp 260 and have some rich bank codes. Is it possible to put pacesetter lt's and/or superchips to lean the a/f out so it would run right or am i totally off track?
well most of the guys that have the cam and get that code, alrady have the LT's, and they still get the code. so i think getting LT's when you do the cam will just help you to be not AS rich as you would be without the headers.
As far as tuning goes.....A new calibration is needed. I think what you are talking about is wide open throttle.
A cam and headers will lean out any pre set air/fuel ratio if not designed for it.
Daily driving, the long term and short term fuel trims will need to be corrected also.
Sounds like you need custom tuning to be safe.
1 - 3 of 3 Posts
