HORN CHIRP DISABLING / ENABLING
The horn chirp can be toggled using a DRB IIIt or
by using the Remote Keyless Entry (RKE) transmitter
that is already programmed to the vehicle.
To DISABLE (cancel) the horn chirp feature:
(1) Enter the vehicle and close all doors.
(2) Fasten the seat belt (this will cancel the seat
belt chime).
(3) Turn the ignition to the ON position.
(4) Press and hold the LOCK button for 4 seconds.
Within 6 seconds with the LOCK button still
depressed, press the UNLOCK button. When a single
chime is heard, release both buttons.
(5) Turn the ignition OFF.
(6) Turn the ignition ON or wait 60 seconds.
(7) Test the horn chirp feature by pressing the
LOCK button.
If a chime is not heard, program mode was canceled
before the feature could be disabled. If necessary,
repeat the procedure.
To ENABLE the horn chirp feature, repeat the
above procedure.
OPTICAL CHIRP (FLASH) DISABLING / ENABLING
The optical chirp can be toggled using a DRB IIIt
or by using the Remote Keyless Entry (RKE) transmitter
To DISABLE (cancel) the optical chirp feature:
belt chime).
depressed, press the PANIC button. When a single
(7) Test the optical chirp feature by pressing the
LOCK button.
To ENABLE the optical chirp feature, repeat the
above procedure.
UNLOCK SEQUENCE
The unlock sequence can be toggled using a DRB
IIIt or by using the Remote Keyless Entry (RKE)
transmitter that is already programmed to the vehicle.
To toggle between Driver door first and Unlock all
doors function:
belt chime).
(4) Press and hold the UNLOCK button for 4 seconds.
Within 6 seconds with the UNLOCK button
still depressed, press the LOCK button. When a single
To toggle this feature, repeat the above procedure.
DR POWER LOCKS 8N - 9
REMOTE KEYLESS ENTRY TRANSMITTER (Continued)
