1 - 6 of 6 Posts
The problem is that when my headlights are on so is my right turn signal, when they are off and i put on the right turn signal my left ones blink also but not as bright. and when i have my dimmer knob set on a cetain spot it will also blink my interior odometer and over head gauges any help would be great thanks.
and i have changed the head unit and taken out the factory amp, but this was 2 years ago the problems just started.
Sounds like a ground fault in one of your right turn signal lights.
Pimp On Sir Don
Is that engineez for a burned out light bulb? :D
(Sticking tongue out), no...I think it's in his harness (like Greg over in DOC). Since you've replaced the taillights, I'd start looking there. Of course, you COULD have a goofy bulb...lol
Just an update on the problem, it was the bracket on the right rear tail light must have had a short in it. So I popped the one off my stock tail lights and gorilla glued it on problem fixed. ****for any one in the future I was told all domestics run there dash lights through the tail ligts so if they flash the problems in the rear****
1 - 6 of 6 Posts
