Ok, I've had my 99 durango 5.2 since it had 55k miles. It now has 85k so I decided to change the plugs and wires for the first time today before winter. I used the autolites 3923's. Well, I'm all done now, but the truck is popping while idleing. I haven't even driven it yet. Just it sitting there it's backfireing. I checked all the wires for tightness and in the right order. All seems well. Only thing I can think of is plug gap. I read on here to gap the plugs at .40. Well, I did that, however I checked the previous plugs that I pulled out and they were at .60-.65. They were champion plugs. So now I don't know what to do. I put a new cap and rotor on, new wires, and new plugs. What do you guys think could be wrong? TIA.
Shawn
If it's not running correct, I'd say some wires must be crossed.
G
I second neil's diagnostic. Even though you checked the wires, double check them. It does get quite tight around the distributor cap and you may have easily mis-matched something. Good luck.
Did you number the wires when u pulled them off with the correct positions?
