Hello Everyone! My 99 Ram 1500 with 5.9L won't start all of a sudden. I drove my truck last wednesday, it was around 0 to -10 degrees outside and started right off, cranked kinda slow but started right up and ran great as always. So 2 days went by until i needed to drive my truck again, so I went to start it and it turned over really slow(keep in mind it was MINUS 20 degrees) but it finally fired and ran for a few seconds then died. My battery didn't have enough juice to restart it so i hooked up another truck to jump start it. I tried starting it again and it would turn over....sputter a fire.....turnover....sputter a fire....and keeps doing that. (Acts like a carbureted engine that is flooded)
So i thought well maybe its just so could out that the gas could have frozen despite having already put in Heet in my last fill-up of fuel. So i pulled it into our shop that is constantly 50-60 degrees. Its been sitting in there for a couple of days and will not start! All it does is turnover....sputter a fire...
Things i've done or checked for:
Charged the battery back up and is good(less than a year old)
Has spark
Looked down into the intake manifold and nothing suspisious can be found
Fuel is getting to the fuel rails and fuel pump is working (less than 6 mon. old)
Antifreeze is still full and is in good shape.
The only thing I have found that isn't right is my oil level was a little high and smelled like gas. What could cause this?? Even when i crank it over there is an aroma of gasoline in the air.
This all happened after 2 days of sittin in -10 to -25 degree temperatures in a car port. I am in need of help badly! I'm hoping its something simple so i don't have to haul it in to have it worked on, but i'm afraid it's not gonna be that simple.
Your help is much appretiated!!!
Has spark
