I have a 97 w/5.2L. Just today on the way to work, the truck starts freaking out. I came to a stop and as I applied the brakes, the oil pressure drops and the steering loses power. I shut it off and turned it back on and everything's fine. Drove the last 2 blocks to work and the same thing happens again twice. As I pulled into my parking spot, it died again when I put the brakes on. I checked all of the fluids and they are all within parameters.
Any ideas? Anyone with the same problems?
Thanks:gr_patrio
It sounds like you have a bad ground connection. Check the Negative post on the battery(turn it with your hand).
Just Call Me Oz
Sounds like the O2 Sensor is going.
