1 - 2 of 2 Posts
Looking for information on where the TCM is located on 1994 Intrepid. The car starts like a dream but the transmission on the other hand gives a fit. It will not go into gear when you first start the car. you have to let it warm up and then just maybe it will go into gear.Anyone that could help me would really be apprecited.Someone please help.
Your tranny is going into limp mode. When was the last time the tranny fluid was changed? Does it only do this when it's cold ? If so then I'd start first, changing the fluid with ATF+4 and a new filter. What maybe happening , is your pump is loseing it's prime, and can't pump old thick fluid passed the filter. I's try the cheap stuff first then work your way up.
1 - 2 of 2 Posts
