1 - 2 of 2 Posts
I have a 2001 Dodge ram 1500 with the 5.9 and I can't get the transmission to shift from first. I've replaced the governor pressure switch and solenoid, out put speed sensor, transmission filter and I've adjusted the TV cable and none of these have made a difference. So any help would be appreciated
One cause to rule out is a low fluid level or a plugged transmission fluid filter. Delayed shifts can also be caused by internal hydraulic leaks in the valve body or failing internal transmission seals found on clutch pack pistons and piston o-rings.
1 - 2 of 2 Posts
