Hello everyone. I have been doing some research on where to put the sending unit for my transmission gauge. I have seen everything, cutting the line and using a manifold system , parts from home depot with cutting the line to putting it in the test port on the tranny. My question is that there is no mention of just disconnecting the line from the tranny to the cooler at the tranny and putting in a adapter and Tee that will accomadate the sender. Is this a bad idea or is it just not possible. Please chime in especially if someone has done this or if there are some unseen problems with doing it this way. I plan on putting in a pillar gauge in the next couple of weeks. Thank You in advance.:gr_patrio
