As we know the LH platform uses the 42LE transmission. Isn't the best transmission but it works. What if we can drop the 42LE and toss in a manual VW / Porsche transmission? A company called Kennedy Engineered Products, Inc. makes a adapter kit to use a VW / Porsche transmission. They have it listed under for a Chrysler 300m. This can be used on all LH platform cars.
They don't know much on the install and only recommend for racing proposes. I have been thinking about this. Get a older mechanical transmission so there isn't much to deal with the electronics. I think the adapter has a slot for the crank sensor. The rear O2 sensors use the transmission harness but you can leave in the harness or build a new one from scratch and only leave in what is needed like the O2 sensors and the speed sensor. The PCM might need to be modified but a company called B&G Performance that might help on that. I am going to inquire info about it. Also the half shafts. Doubt the stock VW / Porsche half shafts would work. Would have to modify them or get custom ones built. The rest should be a breeze. Install a clutch, ether modify the brake pedal or replace it.
Anyone have any input? I plan on doing this when the 42LE dies in my car.
