hey guys im having one heck of a problem, it's going to be a long story to get all the facts in so here goes:
ive got a 2000 dodge ram 1500 4x4 with the 360, 392's 35 inch tires
cold air intake
one friday night after a few to many beers in buddys shop we got the idea we could get some smoke shows goin, well i jumped in my truck and tried to get my big 35's turnin an well i blew the diff out.
SO, over the next day i rebuilt the diff threw it back in and thought i was good to go, jumped in to drive away and this truck is boggin down and locking up the diff, i couldnt get past 40k without skidding to a stop, i figured it was the diff, re did it and same thing, i would get to usually 30k @ 2000 rpm it would bogg to 1500 no matter how much throttle i gave her then full lock up and tires would skid me to a stop. it's like it locks and unlocks it never lasts more than 3 seconds and i have all my gears ( i think) i never make it out of first before it locks up on me
So i popped of the driveshaft figuring i had a piled up chain in the transfer case and yup did it again so popped out the transfer case getting ready to rebuild it when buddy comes by with a code reader and what do ya know it keeps doing the same thing without the transfer case on now only because i have no drivetrain i keep bogging out the motor, it wont stall but @ the rpm where it sits at 30km it wont get past, usually i hit 2k an boggs me down to 1500 or lower.
also noticed the fluid looked burnt and buddy claimed he seen a little smoke coming out the output shaft after i disconnected the transfer case
so now i figure it in the tranny and i popped a couple code which are:
P1740: TCC or O/D solenoid perf
P1757: Gov Press above 3 PSI in gear with 0 MPH
i think it's a 46re, maybe 47re transmission
And now im lost because i dont know transmissions at all.
ive had a couple people tell me its the torque converter and i spoke to my buddy who's dad is a tranny guy an he says it looks like to him that the tranny is going into limp mode and says to replace the governor pressure sensor.
if you guys have any advice it would be greatly appreciated,
feel free to pm as well
V8 uses 46RE
... Best to do smoke shows with selector in manual 1, not D (1st is stronger when in manual 1 as rear band is also engaged).
... "If" you know, might be helpful to mention if trans was in 1st, or limp mode when it locked up.
... This "sticky" thread at top of drivetrain forum may help; see "DRAGS OR LOCKS UP"
http://www.dodgetalk.com/forums/showthread.php?t=197157
.. IIRC breaking driveshaft (or diff) when torqued up hard can raise cain with "overrunning clutch" (a few years ago, tractor/truck pullers mentioned that as a concern).
... P code info; (click near heading for P0 codes)
http://www.obd-codes.com/trouble_codes/dodge/
I blew one out of a 727B that cracked the case. It's also called a sprag. It's a bunch of roller bearings and springs that allow only one direction rotation. When they fail they spin in the case cracking it. The bolt in types are stronger and recommended. Not sure if this is your issue but i would pull the trans and start taking it apart to find out what failed. At least drop the pan and maybe the valve body.
Dodgegraveyard has the parts you need cheaper than a trip to Disneyland. Find them on facebook
