1 - 2 of 2 Posts
07Dakota
I was leaving for work this morning and when I started my truck up it started out in a higher gear. Im not sure what gear but i know as i pulled out it ran about 2500 rpm for a very slow take off. I turned around to come back home and manually shifted into 2 and even first and the transmission shifted very hard. I left the truck running for about 25 minutes after i parked it. put it in neutral, checked the transmission. everything was good. i shut the truck off and waited about 30 more minutes and started it back up n it was fine. going to go drive it here in a few again to check once more, but that obviously isn't normal and Im trying to find the cause. any help would be appreciated.:gr_patrio:gr_patrio
Premium Member
Welcome to DT!
I'm going to move this thread out of the Welcome Section and put it in the Dakota Section. There it can be seen by more members.
1 - 2 of 2 Posts
