I have a 2002 1500, 5.9 4x4, 56,000 miles. Stopped at the store and when I started the truck it would not move. Had it towed to a shop and they thought it was the cable. Had it replaced but didn't fix the problem. The shifter would move to different selections but would not move. If you put in reserve it would seem the truck was in a bind. I had to remove the drive shaft to roll the truck. Someone told me it may be the overdrive out. The pan was pulled and no metal found and the fluid was clean. I plan to take out the transfer case tomorrow to check the transmission. I had the truck checked for any codes and it did not show any.
Anyone out there have similar problems.
