In 15mo, my Durango hasn't let me down once, but now it started pouring ATF fluid out a tiny hole at the junction of the transmission and transfer case. The truck had been sitting in the driveway for a few days, then all the suddent it started leaking like crazy; probably lost a quart or two before I could get a pan under it.
At first, I thought the hole had corroded through beacuse the opening looked mis-shapen, but now, once I cleaned it out, it appears to be a machined hole. Can anyone confirm whether or not this hole is supposed to be here? Could it be that a seal has broken inside?
I posted a labled picture of the hole where the fluid came out. Note that the hole in the casing is located at the lowest bolt that holds the tranny and xfer case together. You can even see the threads of the bold inside the hole.
Any help or suggestions would be greatly appreciated since I have no idea what to do, or where to tow the truck for repairs.
Thanks!
Thanks!
