1 - 2 of 2 Posts
Hi, I am new to this forum and have an issue (who doesn't).
Anyways, trans slipping at 45-65 mph. No fault codes. First thing I did was change fluid and filters. No difference. Replaced input and output speed sensors, no change. Took out valve body and replaced solenoid pack. No difference. It shifts fine, no jerking or bucking. Worse when i go up hills. I thought I read somewhere it might be the throttle position sensor. It has also recently started doing it at lower speeds. the throttle body looks like all one piece and no way to take apart. Do i need to replace whole throttle body?
I am trying everything I can not to take it in to tranny shop. I did 2 years ago and they supposedly rebuild it with the "toughest" transmission parts around. Yeah, the same guys that stripped out 3 of the trans pan bolts...anyways. any help or suggestions would be appreciated. Thanks.
Have you adjusted the bands? Loose bands can lead to slipping I read and learned about watching Youtube videos on slipping transmissions.
1 - 2 of 2 Posts
