Folks ,
My understanding is that you can mount the trans temp gauge in the test port on the tranny. I have seen a pic of this on a Ram 1500 , however I am not sure if the dakota has this port or not ?? I would rather use this port instead of using the line to the cooler. For the oil temp , does it make sense to install a tee at the location of the stock pressure gauge ?? Put the stock pressure sender in one side and the temp sender in the other ?? or is there a better place for the oil temp sender ???
Mark
