i have a 2005 1500 qc hemi 4x4 with the 5 speed auto trans (545rfe??) does anyone know how much atf i will need for a trans service, and does the transfer case drain at the same time?? thanks as always for the info!!!!:worthy::tup:
Xfer case is seperate and fill the trans till it shows right on the dipstick it all depends on what coolers and aftermarket trans pan you have if stock your owners manual has the fluid chart in it
6.5 qts with a pan drop, 16 qts with a complete system flush. Be sure to recheck fluid level after a short drive as the two filters will soak almost a quart of fluid.
Buy like 10....whatever you don't use just return it.
Related Threads
DodgeTalk Forum
4.7M posts
290.1K members
Since 2002
