1 - 20 of 21 Posts
Ive searched but cant find the recent write up done on changing the transmission filters, and was hoping some one can help as I can NEVER get the [email protected] search to work for me they way I want it to. Also the guy at O'reillys is telling me I need to know what kind of transmission I have (44RE or 48Re) how do I know, and out of curiosity whats the difference? Last one how much ATF do I need?
thats the one THANK YOU!!
You a 5-45RFE transmission. You will need two filters, one is a flat filter, the other a spin on. Also I recommend buying a cheap Seal Puller. They are like $8 at Harbor Freight. You gotta pull the old seal off, mount the new seal and then put the flat filter in place. ATF+4 is the tranny fluid you need. It's not hard, just messy.
Discussion Starter #5
How much aft will I need, and Do the numbers stand for something in the transmission name?
For just a pan drop I think you need like 8 quarts if I recall. I bought Mopar ATF+4 from Walmart when I did mine last. But any auto parts place carries. Valvoline makes it and there are even store brands of the ATF+4 now.
For more info on the 5-45rfe, which by the way is the same transmission as the 45rfe, look here: http://en.wikipedia.org/wiki/Chrysler_45RFE_transmission
Acts 2:38-39
Follow the Transgo link in my signature. I know you are doing just the fluid change, but I did get both filters as well. Hope this helps. I brought a picture of the "can" filter with me, and that enabled the parts guy to find it. PNs are listed in my linked thread. Enjoy.
Discussion Starter #9
Well well went to auto zone and asked for the filters and they gave me the kit but there isn't a rubber gasket in there, what gives. The box is labled TF349/T770 high performance automatic transmission filter. Is this wrong?
mafosa
i just used rtv (black) if i recall.
You don't have a gasket from the factory. I use RTV.
Discussion Starter #13
I got rtv when went there I just thought everyone had the gasket in the pictures, thanx again.
LPG Hemi
Don't forget........as was told to me just recently............have PLENTY of newspapers to hand as it's soooo messy lol.
Al.
Discussion Starter #15
Really; that bad?
Thread Derailer
8 liters of fluid are going to splooge all over the place once the pan gets loose
i'm surprised you didn't get a new gasket for the filter with the kit
In case anyone else gets in here and wants some help here are the Dodge part #'s for the trans filters
Spin on filter - 5179267AB
Flat filter 2wd - 5015267AC
Flat filter 4wd - 5013470AC
I RECOMMEND FUKKEN WAX
I lay out a big blue tarp with a barrier of kitty litter. That way you don't get cutoff by the wife for a few weeks when she sees the mess.
Discussion Starter #20
Don't let her keep it from you, just remind her just how big the ocean is, lol :D
1 - 20 of 21 Posts
