1 - 7 of 7 Posts
Hillbilly Deluxe
When i put my truck in 4low it will move but as soon as it gets to about 2000 rpms it starts to slip and rev until i let off and then it will shifts into second and is fine. 4H is fine. When in 2wd it hesitates going into second gear, but everything else is fine.
It all started after I pulled a gravity wagon with about 15,000 lbs. of seed wheat in it.
Transmission Man!
The transfer case has nothing to do with the transmission upshifts.If it is a transmission problem,it will do it in 4WD or 2WD. It sounds like you have a transfer case problem.
Hillbilly Deluxe
Thanks man. Atleast I know which direction to head in
Hillbilly Deluxe
Another question.
Why doesn't it occur in second gear?
Does it do it if you manually select 1 gear?
Hillbilly Deluxe
I'm not sure but I'll try it tomorrow
Hillbilly Deluxe
Yes it does it if you manually have it in first
1 - 7 of 7 Posts
