1 - 3 of 3 Posts
I have an 02 ram with the 5.9 ltr and auot trans. Im having an issue when taking off from a stop, the transmission dosent seem to shift gears out of first until about 2500 t0 3000 rpm. I have already replaced the tranducer and the solenoid in side the transmission. Any suggestions would be great.
You've probably already done this but just throwing it out there.
Did you check the fluid level after the transmission is hot and in neutral?
yeah ive checked the fluid level after i had to drop the pan to replace the two sensors in the transmission, so the fluid is new and at right level and also i replaced the filter while i was in there. thanks for the suggestion.
1 - 3 of 3 Posts
