Hey I'm having some issues (this is my first tranny rebuild ever so I could really use some insight), I believe I have everything lined up. I made sure the TC was seated properly (double click) before hoisting it up. Also made sure I put the bellhousing bolts on first and then checked the TC again, everything was good. Put the TC bolts in by hand and checked to make sure the flexplate was turning with the TC by spinning the crankshaft pulley...that was good. But for some reason I'm getting a no crank now, I checked the started and that's good, the only issue I can think of is I didn't mark the TC BEFORE I took it out, do all four pads have a specific area of the flexplate?
