I had my truck in 4HI today because there were some pretty fair snow banks in the road. When I shifted out of 4HI Lock everything was fine. I put the truck in park to load something in the back and when I put it into drive again it lurched ahead pretty hard. Within a few seconds the check engine light came on. When I pulled away it took almost 2500 RPM's just to move the truck. I stopped and put the steering column into neutral, then the transfer case into neutral. Then I put the transfer case back into 4X4 and shifted the steering column back into drive. Again the lurch forward and it still needs higher RPM's to start going. Once I am going it is fine. I put everything in neutral because it felt as if I wasn't getting a good gear mesh, like I was slipping. I am getting no noise or smell. When I got home I checked the code and it is P0700 (Ground Circuit Open, TCM Internal Error). What's the next step? Is it a HUGE problem? Am I hurting my tranny driving it like this?
