1 - 2 of 2 Posts
I have a 75 pw with a 727 and when I drive it and stop at a light the tranny will not down shift back to first unless I manually down shift it . any help is greatly appreciated. thanks
governor sticking. though my 78 Fury was doing the same and a trand fluuid and filter change solved it. The governor is on the output shaft, a little valve in (on? its been a while) the parking gear pawl "gear" serviceable in the truck if it were a 2WD, but a 4WD the T case would have to come off as would the rear case half; I guess you could service it in the truck with a jack under the pan.
1 - 2 of 2 Posts
