1 - 3 of 3 Posts
ACE
put remanufactured tranny in buddies 00 ram 4x4 5.9 qc. has no first gear and the check engine light came on instantly with code p1762. shut truck off and checked fluid. low a quart. started back up and stuck in first. then disconnected battery started up and light came back on instantly with no first gear. what gives this was the secound tranny threw this company. is it something im not doing right? could it be the computer? please help a.s.a.p. thanks tom
Do It In A Van
Are you positive you purchased the correct transmission? Seeing as how the transmission is electronically controlled, it would be imperative that the right year transmission is used. At least I would assume this to be the case.
Chicks dig bench seats.
I know when mine was replaced they needed the VIN and the # off the tranny in order reman me the right one. Just goin off Dodgevanman's reply.
1 - 3 of 3 Posts
