1 - 11 of 11 Posts
ok heres the deal i got my hp and tq almost where i want it. th eproblem is now if i dont get some traction my tire bills going to be outragous lol. whats the best mods to help this with out putting ugly traction bars on it?
Get some 4.10 gears and an LSD. I did this and gained 6/10ths in the quarter on 20" wheels. I haven't even tried running it with this set up on 15"s. LSD will help you out with traction, too. I have the AuburnGear LSD unit.
EDIT: Nevermind, I just reread your list and saw that you have a Powertrax unit. In that case, just get some gears!
i have a power trax system already this is like posy an lsd would be a step down right ?
also i think the extra unspung weight from bigger rim would actually slow me down.
ive looked for the factory gear ratio do you have ne idea what it came with stock or how to find out
I never said switch to a bigger wheel, I'm just saying that I gained 6/10ths of a second on the gear change even with big ass wheels. What I'm tellling you is to get 4.10s.
Yours is either a 3.55 or 3.92, but probably a 3.55. Mine was 3.55 stock, but you can call or email Dodge with your VIN to find out what gear ratio your truck is, or it could be on a sticker in your glove box, or you could crawl under the truck, look at the differential, and there is a tag that lists the specifications.
ok thanx for the help
How will going to a higher gear ratio in your diff effect traction? It will shift your torque band. You will have more torque at lower engine RPM's with a higher gear ratio. Tires and lockers (or LSD's) are the main way to improve traction, but I am not sure I understand the connection between a shift in your torque pattern and traction.
It's not really a shift in traction, but the dude says he wants to be in the 12s, I'm telling him how to knock several tenths off his time which is a significant gain. Who really cares what my post relates to, it is good advice for how to go faster. Originally I told him to get a LSD + gears, after reading that he already has the Powertrax, I told him he needed to get gears anyway and that would seriously help him. I also advise getting a good drag radial because that will help on the track.
ok I see what you are saying.
Some other things you can try are wider tires, more weight in the rear of the vehicle and a Roadmaster active suspension. All of these mods will help prevent your rear tires from breaking loose on pavement.
Discussion Starter · #11 ·
ok yall got what a Roadmaster active susp? iv never heard of it.
1 - 11 of 11 Posts
