Looking to add some traction to the rear wheels on my 01 4x4 daily driver. Anybody running a Powertrax? How's it on the pavement both wet & dry? Any info regarding limeted slips vs. lockers would be helpfull...Thanks guys! :gr_patrio
I wouldn't be comfortable driving a locker in the snow. I don't like driving the cherokee in the snow and it's only LS. With open diff, atleast one tire stays planted to keep the vehicle pointed straight. With LS and locker, both wheels spinning means less traction & control. With careful driving you can do it, but I wouldn't want my wife driving in the snow with a locker in the rear.In regards to the rear end...The truck is my daily driver/work truck as well as off-roader. How's the Detroit Locker on the pavement? Will my wife kill herself if she takes it to the grocery store in the snow? Can you tow w/it? Does it chew up tires going around corners? Any info would help! Am ordering new gears soon & would like to add the traction at the same time.
Thanks again!
Someone does make a selectable locker for the 9.25 axle, ARB!nhlbill said:I will agree with 50% of the Detroit info posted above. It has killer traction off road and is a very solid, strong differential that will last darn near forever.
As far as Daily Driving with it, I find that it is noisey/clanky/jerky and sometimes down right scary to drive on the street with it. It can have torque steer occasionally too. This is all from a Detroit "Soft Locker" application in my Jeep TJ. Which was designed to "Soften" some of the harshness of the Detroit locker. The "soft locker" is not available for the Chrysler 9.25, so you get the old style "rugged" one.
Your wife will definetly not like driving it at all IMO.
If you off road quite a bit, the Detroit is awesome and has it's trade off's that make having one worth while. If your truck is a mostly DD and only off roads occassionally, I would not recommend one.
If you absolutely have to have a "Locker", the Powertrax No-Slip or Lock-Rite are an economical solution for the occasional off roader. These "lunchbox" lockers add strength over your stock open diff and have 100% lockup traction like the Detroit Locker does without the slop and loud noises traditionally associated with a Detroit (lunchbox lockers do make a "clicking sound" around corners, but not the clanky noises you get with the Detroit.).
Lunchbox lockers are not anywhere near as strong as a full Detroit, but are typically much cheaper. Labor to install them is way less too as you do not have to set up the differential again, not even backlash, as you are reusing the stock carrier.
All that said, if you want smooth traction for your DD, get a LSD like the Trutrac or Auburn unit and live with it's limitations off road.
A traction step-up from the LSD is to add a "lunchbox locker" to your open carrier, and a full out strength and traction improvement would be a Detroit. All of these options have their own characteristics and limitations................................................................................that is until somebody comes out with a selectable locker for the 9.25 rear and then all bets are off!![]()
No disrespect, but the reason your locker / LS was so harsh in that TJ is just that.... it's a locker / LS in a TJ. A 94" wheel base is going to react a whole lot different with a locker in the rear end during a turn than a 116" wheel base. Tighter turns with the shorter wheel base means you need a lot less input to load and unload that locker / LS.nhlbill said:I will agree with 50% of the Detroit info posted above. It has killer traction off road and is a very solid, strong differential that will last darn near forever.
Just looked it up myself. It's not listed on their PDF files on ARB's website. It has a big 'ol N/A right next to it. What it does have is the D44 front part number listed just above where the 9.25 part number would be.rski186 said:Wish I new about the ARB last week when I ordered a Detroit Trutrac w/my new ring & pinions! I didn't think a ARB was availible for a Chrysler 9.25" rear... Are you Sure?
I would have gladly spent the extra $ to have a selectible locker.
