Good Advice!!MrDestinE said:My Track Prep:
Lose the Tailgate, Spare, everything that will fall off of the truck...
Install Drag Radials and street 17s on the front
remove the upper portions of the sway bar and rotate the bar to clear links ( not too high ) I do not remove the bar as I use it on the street.
install front bumper insert with hole for ram air to filter
If I feel like I have the extra time: install grill inserts, remove wipers and antenna ( have not ever really seen improvements there )
Fold in mirrors at the track and make tire pressure adjustments, 60 for the front, around 30 for the back, variable there on the back.
Thats it..
TJ
Makes the front tires just kinda glide against the track for less resistanceeatsleepdrivesc said:why sixty up front!
I think i'm gonna pull my pass/center seat for saturday. I really want a 14.7 out of a stock rc 4x4Jimmy TJ said:My usually track prep was to drive to the trackbut then again I have a big 'ol QC that is never going to be running awesome times like those guys. I'm going next saturday and am going to be dropping so weight here and there. Gotta hit at least a 14.99
make sure there are no trailers on your hitch tooBrandonSC said:One thing I have ALWAYS done that proves to work quite well is make sure to leave the emergency brake off. I know it sounds crazy, but trust me it works!
Also, are you guys sure launching is better than just straight flooring it. I've always found it better to just get on it instead of powerbraking.
