:metoo::truestory:i bumped mine up to 40psi and it hasn't come on anymore
Exactly! It was 41 this morning and stupid light came on againStrange, if you have nitrogen they shouldnt be effected by temp changes.
X3 :truestory: My ram was doing the same thing its effin annoyingi bumped mine up to 40psi and it hasn't come on anymore
I also put mine at 40 psi and it has not come back on.Anyone elses tpms dash light come on when its cold? It seems like everytime it drops below 40 the warning light comes on, then in the afternoon it goes off. What gives?
by the way, all tires have 35lbs of nitrogen
Not on mine, and 40 isnt "very" cold weather either...I was out in weather in the teens recently with zero TPMS issues. I did have it come on the day after I bought it...one tire was down around 32 if I remember correctly.The TPMS will come on in very cold weather, happens in all vehicles with it. You don't need to add more air. The pressure isnt low, its just not calibrated for cold weather.
Well, i was referring to COLD weather colder than 0 (-20°c). It usually seems to send it off. 40 is not cold at allNot on mine, and 40 isnt "very" cold weather either...I was out in weather in the teens recently with zero TPMS issues. I did have it come on the day after I bought it...one tire was down around 32 if I remember correctly.
I dont think anyone said that temps would'nt effect tire pressure filled with air, thats why people use nitrogen...it isnt supposed to be effected by temperature changes.Whoever said the cold weather doesn't change your tire pressure is incorrect....for every drop in temp of 10 deg F, you will lose roughly 1-psi because the air inside the tire will contract significantly, causing the tire pressure to fluctuate....when it warms back up, the air will expand again.
Actually it was said by bruteforce, "The pressure isnt low, its just not calibrated for cold weather".....when in fact the tire pressure IS low because of cold weather. You will always lose a few pounds when the temps get colder.I dont think anyone said that temps would'nt effect tire pressure filled with air, thats why people use nitrogen...it isnt supposed to be effected by temperature changes.
