I haven't looked at the cruise controls, but I will if it turns out my original idea isn't so hot. Basically I'm looking at the Accelerator Pedal Position Sensor (APPS) which is that white thingy hanging on your gas pedal. We don't actually want to mess with the sensor itself because it's calibrated on the pedal. That means if you have to have it replaced, they replace the APPS and pedal together as a single unit.
A position sensor is a pretty simple mechanism in general. Dodge threw a slight curveball in there as there are two sets of sensor lines and returns. One set is always half the voltage of the other. So one should have 0.6v - 0.8v up through 5v and the second one should never get higher than 2.5v. If it was a single sensor return, it'd be easy as pie. The DPDT switch would break both return lines and route them through a DP rheostat. I need to verify the resistances and voltage on each of the return lines and determine whether the half voltage on the secondary is a check and balance type thing or not.
However, if someone gave me an arbitrary RPM that they think would be a good one, I dunno, maybe 1,200 RPM or something, then I could do away with the whole variable idle and just wire some resistors in on the DPDT switch which would give you a fixed 1,200 RPM with just the flip of one switch.
