1 - 14 of 14 Posts
Northeast DDRC Webmaster
I lowered teh front end by turning the torsion bars. I turned them a full 2 times. I want it lower, but don't want to harm my four wheel drive. What's the limit? Help me out, quick answer please.
Patriot....
Assuming the 6-7 turns that people do to make the front higher, 3-4 to lower shouldn't hurt as long as you get the front end realigned so the caster/camber is correct.
Arite...did 4 full turns....the washers started to get loose and turn with the nut right at 4 turns...don't want to go any further if it will screw up anything...also I have 1/2" blocks in the rear...any thoughts?
Here's a few pics...
That's not really a good comparison, GM trucks have much larger wheel wells than our Durangos do. Find a Durango to park next to or something, I know they're not rare or anything LOL
"TRUCKIN"
tahoe doesnt equal durango..........tahoe is about 2'' taller than my durango, both stock
Discussion Starter · #8 ·
AH cmon...geez...ok then measure you space between the top of your tire to the wheel-well. Not sure on my tire size diameter, but there's even 4inches all around space. My truck is 3 inches lower than stock at the roof.
Patriot....
it's noticeable now with a before/after. Have you had the alignment checked?
Discussion Starter · #11 ·
Nope no alignment checked yet. I deffinately need it though. The ride is now smoother, it grips much better, there's almost no body roll anymore.
is this a joke?
"TRUCKIN"
FSTDANGO 3
Technically
Whebn you want to lower your truck you must crank down 1 more crank than you actually want then crank that 1 back in this way the washers wont come loose Dodge specifioes that you must always be adjusting up only so if you wanted a 2 " drop crank down 8 cranks then crank up 1
each crank is worth about 1/4 "
So if you want a 1" drop 5 down 1 up
Hope this helps
Steve
1 - 14 of 14 Posts
