Great wright up!
JonHemi said:Looks great. Can you fit 35 inch tires on a 1500 that has just had the torsion keys cranked? Also, why would someone buy new torsion keys to achieve a level truck if simply turning the screw a few times will do the trick. All answers are welcome. I want to put 35x12.50x18's on and don't necessarily want a huge lift.
Thanks,
Jon
I did the torsion Keys instead of cranking the bolts and added a 2.5" add a leaf in the rear .... already had the front leveled and didnt like it when I towed the boat so added the leafs to give it that dipped nose..... I think I am from center rim to lower fender edge like 40 or 41 inches which I will verify for you later today. I am running 35x12.5x20 Mud Grapplers the only rubbing I get is on the sway bar (Looks Shiney) on hard right turns and the plastic on the inner fender well on the drivers side only.JonHemi said:Looks great. Can you fit 35 inch tires on a 1500 that has just had the torsion keys cranked? Also, why would someone buy new torsion keys to achieve a level truck if simply turning the screw a few times will do the trick. All answers are welcome. I want to put 35x12.50x18's on and don't necessarily want a huge lift.
Thanks,
Jon
I am one of those that didnt want to do the bolt crank lift cause of some of the stories I had heard but havent seen any documented but like you said for piece of mind.03RAM59L said:There have been quite a few folks on here who have squeezed on 35's after doing a TB crank. Off hand, I can't think of their names, but there's plenty around here.
Some people feel uneasy about cranking the torsion bars as they have had/seen/heard bad things with premature wear on parts, so they get that extra peace of mind with a kit that was made for this purpose. Those who do adjust their torsion bars do so because it's FREE and QUICK. Just my opinion.
right on man. i didn't want to come across to anyone as bashing them for their choice. i probably would have gone the route of the torsion keys too, but with a baby on the way i have to keep things simple and cheap.sherdep said:I did the torsion Keys instead of cranking the bolts and added a 2.5" add a leaf in the rear .... already had the front leveled and didnt like it when I towed the boat so added the leafs to give it that dipped nose..... I think I am from center rim to lower fender edge like 40 or 41 inches which I will verify for you later today. I am running 35x12.5x20 Mud Grapplers the only rubbing I get is on the sway bar (Looks Shiney) on hard right turns and the plastic on the inner fender well on the drivers side only.
Any time you change the angle's on the front end from factory specs you are gonna get premature wear ........
and I agree with the other guys make sure you get an aligment after the crank or you will be eating tires pretty fast.
I dint take it as bashing ..... and I understand about the baby issue of money cause I have a 3.5 month old daughter and money is very tight at the moment03RAM59L said:right on man. i didn't want to come across to anyone as bashing them for their choice. i probably would have gone the route of the torsion keys too, but with a baby on the way i have to keep things simple and cheap.
I had the same issue with a heavy trailer (or loaded bed), so I put air bags on. They let me sit level when the truck's empty, but I can air them up when loaded, so I can be level then too.sherdep said:...... already had the front leveled and didnt like it when I towed the boat......
I never did the turn down two and up one but it probably has to do with the front end settling and putting tension back on the bars.Shots said:Congrats to both of you on the new "mods" to the families.
I don't mean to step on your toes hogcrik, but I've read that you only want to adjust the torsion bars into tension (going up). So if you have to go down, you're supposed to go 1 turn past where you want it, then come back up that 1 turn. So if you need to go down 1 turn, go down 2, then back up 1. I'm not sure why that is, I'm just repeating what I've seen here on DT, by other members. Maybe someone a little more suspension educated will chime in and explain it. Great looking truck by the way.
I did two full turns down, to level my truck, no problems I'm happy to report: I haven't noticed or felt any tension loss. But then again it was cranked almost to the max! Minus a full turn!! My local off-road shop had some young kid crank my T-bars last summer, and needless to say, he got a little carried away. The next day I got a wheel alignment at my local Dodge stealership, after that I decided to buy new / longer shocks, and live with it. My front-end was just too tall, even with my rear end sitting better i.e. no sagging - after replacing the OEM shocks with Bilsteins.sherdep said:I never did the turn down two and up one but it probably has to do with the front end settling and putting tension back on the bars.
