Is there any way to override or get rid of the torque management in our trucks.
Bubba Hemi what is the second way to do this?Bubba_Hemi said:Pulling the wire isn't the only way... there is a second way that'll work as well.
I tried this on my truck...got it to work once and only once. Weirdest thing ever....but it was pretty badass. Hopefully if works for ya.Bubba_Hemi said:I'll try and help explain it some more.
Is it the same fuse on 03's as in your picture?Bubba_Hemi said:I never pulled or cut the wire... so can't say for certain, but I'm willing to bet it's the one in the engine.
The other way is with "The Switch"... remove the relay in the fuse box, run a wire from each post there into the cab (with a fuse the same as the relay in-line on one). Here's a couple quick shots to try and help explain. You can search for it to see if it helps explain anything. If not, hit me back up in here and I'll try and help explain it some more.
