1 - 11 of 11 Posts
Jason
About a mile from home the check gauges light came on. The water temp was at about 3/4. I turned the heat on but it was just blowing cold air. Then the temp pegged out. There was a boom and coolant sprayed on the windshield. Found that the hose had separated at the cap. Could it be the thermostat failed to open causing enough pressure to blow the hose apart? I have'nt noticed any coolant leaks. I had replaced the thermostat about 6 months ago with a 160 degree one. I plan on flushing the system, and replacing the stat and hose. Thanks in advance.
160 degrees? That is kinda low for the D. I know many say that the optimal temp for the D is 180 degress but I don't think that would by your problem....
What you say sounds logical... but that would have been ALOT of pressure!! Good luck and Hope you get it working.....
Jason
Yeah, I put it in right before going to Myrtle Beach in july for vacation. Figured it might make the A/C cooler and the motor while sittin in traffic.
RTDurango said:
....after it cooled down of course.
Oh come on... you don't need it cool down.... HEHE.... I have given myself very severe burns because of stupidity :)
Keystoner
I bet that scared the crap outcha....... I've had mine slip off, but not explode
I'm still fond of my WOT freeze plug catastrophe @ 90 MPH.
OH! Also, make sure you rinse things down under the hood a bit, and use a corrosion inhibitor like Boeshield or CRC, to drive the moisture out of relays, PCM connections, etc...
Jason
Discussion Starter #9
Yeah, if coolant had'nt sprayed on the windshield I would have pulled over. It was loud. Also, this happened at 11pm and the temp was 45F outside.
RTDURANGO said:
the fuel air mixture has to be affecting your mileage i would guess.
It must be, the overhead computer says 11.5 mpg
So, you think it was the t-stat not opening that blowed the hose? or is that possible to create that much pressure by itself? Thanks guys!
Hey all, I just had this happen to me, hose completely came off right below the radiator cap. The hose won't stay back on. Any suggestions or tips or advice?
Jason
Discussion Starter #11
1 - 11 of 11 Posts
