1 - 6 of 6 Posts
Top Gun Customz just released the newly redesigned 8" lift kit. Check out the changes
Top Gun Customz NEWLY REDESIGNED 8" Long Arm Suspension lift Kit
Top Gun Customz is proud to release our newly redesigned 8" Long Arm Coil Spring Lift Kit for the 2003-2010 Dodge Ram Diesel 2500/3500 4x4's.. We have thoroughly looked over every component to find where we could make changes and upgrades. We strive to continue to improve on our products all the time. What we have just released, we feel, is the best 8" kit on the market....for several reasons. Only the highest quality materials are used and some of the most innovative designs out there are in this kit. Look below at some of the features that make this kit truly remarkable.
Just a few of the NEWLY DESIGNED Top Gun Customz products that are included in this amazing kit!
Top Gun Customz New "Boxed" Long Arm System: (Click for larger view)
These arms are newly redesigned to accommodate a full turning radius with wider tires. Our lower arms have a slight bend so the larger tires most often used on lifted trucks are not impeded in any way at full turn. Plus, our arms are extremely durable and tough. This long arm system can take anything you dish out and look good doing it!
Top Gun Customz New Sway Bar End Link Kit: (Click for larger view)
We have fixed a problem many experience with their lifted Dodge Rams. The problem is contact between the drag link (steering arm that goes from the pitman arm to the tie rod) and the factory sway bar mount welded to the axle on the passenger side. Often times, with lifts greater than 6", the drag link will make contact with this factory sway bar mount and cause a rubbing issue, which can be felt in the steering wheel. Some have decided to simply grind the factory sway bar mount to the point it doesn't rub.
Top Gun Customz New Dodge Rear Lift Blocks: (Click for larger view)
These trucks use a dual center pin on the rear spring. Our blocks have 3 holes on the top side which those pins sit down into. This "locks" the block with the spring. Most companies use a "universal" rear block that lets the outside two pins "float" without locking into place..
Our blocks are also 3" wide, just like the spring and the spring pad itself. Why mount a CAST block that is 2.25" wide under a spring that is 3" wide? A full 3/4" of the spring will not be making contact with the block.
Newly added Bilstein 5100 Series Shocks: (Click for larger view)
One of the many new additions to our new 8" Long Arm kit is pairing this kit with the great technology of Bilstein 5100 Series Monotube Gas Shocks. Bilstein's 5100 Series shocks feature Bilstein's superior single tube high gas pressure design for the utmost in consistent fade-free performance and long life. Bilstein's patented Digressive self-adjusting valving delivers improved damping control and a smooth ride on all road surfaces at any speed.
This kit is the culmination of many hours of research and development and we could not be more proud of how this kit turned out. Each component in this kit was crafted and designed for the 2003-2010 Dodge Ram 2500/3500 Diesel 4x4 in mind. If you would like to learn more about this kit please visit out website. All of these Top Gun Customz exclusive products including the New long arm upgrade are available separately and we be seen on our site soon. Keep an eye out for these amazing products!
(Choose your year range for the correct kit)
8" 03-07 Dodge Ram 2500/3500 4x4 Long Arm Lift Kit
8" 08-09 Dodge Ram 2500/3500 4x4 Long Arm Lift Kit
8" 2010 Dodge Ram 2500/3500 4x4 Long Arm Lift Kit
can we see some pics of it on the truck or have yall not done one yet
We do have some rough images right now. Here is one:
We are currently finishing the install and we will have some good pics of the block, Long Arms and the rest of the kit to show you guys VERY soon. Keep an eye out for this one.
that dose look pretty darn big but that dose not look like a 2010 dodge is it, jus wonderin thanks
No that is not a 2010. That Dodge is a 2005 model. It is the first truck we personally installed this kit on so far. One of the great things about our design is we are able to use it on every year from 2003-2010.
i will be buying this kit as soon as i can save up the money......it looks very well thought out and well put together
1 - 6 of 6 Posts
