I just want something that is better than stock, but don't want to spend an insane amount of money.
What is recommended?
Thanks!
hey man, do you know what the stock plug is? should say under the hood or in your owners manual. The manufacturers don't have 2010 app data out yet...
I didn't have a manual, had to download it. Here is what I found.
Spark Plugs - 5.7L Engine LZFR5C-11 (Gap 0.043 in [1.09 mm])
So your stock plug and its upgrade equivalent are OE only - they'll only be available through the dealer for the next few years. If you wanted to get the "official" upgrade plug from the dealer the part number is PLZFR5B13EG but I would take a guess it will likely be somewhere around $25 per plug.
The differences between your stock plug and alternatives that are currently available are minimal. The main difference is the stock plug has the metal shell that extends maybe 2-3mm further. If it makes any noticeable impact we can just close the gap a little bit.
Alternatives that are available are:
Pulstar DG-1c - Pulstar's standard nickel plug at $7.95 per plug
Pulstar DG-1i - Pulstar's iridium version at $12.95 per plug
NGK ILFR5B-11 - NGK Long life iridium plug at $12.06
NGK LFR5AIX-11 - NGK iridium plug at $8.48
Denso IKH16 - Denso's iridium power plug at $9.99
