1 - 11 of 11 Posts
Power Smurf
here is my latest to do list for the truck. just looking for input i guess. Let me know if i should change, add, or delete anything...
. install 180 t-stat
. replace bushings
. replace rack and pinion
. solve problem with leaks above rack and pinion
. get gears and diff installed
. fix paint and dents
. bedrug
. fiberglass bed cover (with spoiler?)
. leather wrap seats and modify dash (carbon fiber dash parts?)
. custom center console with shifter relocation (gauge pod)
. custom door panels (carbon fiber gallardo style?)
. higher mph gauge cluster
. install 4th gen steering wheel (if its possible)
. carbon fiber Venom hood
. powdercoat calipers
. buy mounting brackets from AirRam
. buy lower intake manifold for 02-03 cobra
. buy eaton m112
. have supercharger assembly installed along with aftercooler system
. install 2800 stall converter
. rebuild engine with new pistons, rods, lifters, valves, and valve springs
. reconfigure supercharger for more boost
. wet direct injection nitrous
. larger cams
. modify exhaust
. underdrive pulley
. racing slicks for rear
. GO TO TRACK!!!!!!!!!!!!!!!!!!!!!!!!!
?'s mean im thinking about it
MADBRAD
Wow! Thats quite a list!
Hemi Elitist
total cost?
enough to buy a sports car?
-Arana-
Damn brandon lol is your job hiring
Power Smurf
Discussion Starter #5
total cost? probably 15k or somewhere around there
im thinking of getting a either a challenger, camaro, or 5.0 some day anyway and making this truck my project. its my first truck so i probably wont ever sell it. its worth more to me to keep around
Creature Of The Wheel
sounds like it will be a mean looking and performing truck when your done with that list.
if only i had that much money....
Power Smurf
-180 t-stat is in
-new bushings and control arms have been purchased and will be in next tuesday
-rack and pinion was fine
-gears and diff going in monday
-scratched bed cover idea
-scratched gauge cluster idea
updated list---
. bedrug
. Fiberglass Venom hood
. buy eaton m112
. larger cams
. modify exhaust
. underdrive pulley
'11 5.7L R/T Classic
Honestly, before you throw all those performance mods at a 4.7, I'd swap in a hemi. It's good for about as much hp as the rest of the performance mods you listed, and then you can stack the supercharger, cam, etc. on the hemi.
Power Smurf
Discussion Starter #11
ok list just got a lot shorter!!!! (simpler too) but not necessarily cheaper unfortunately...
. TURBO KIT!!!!!!! with boost controls :)
. bedrug
. larger cams
. modify exhaust
. underdrive pulley
ceri - i have seriously thought about the 6.1 idea but thats a lot of work, plus i like the idea of a smaller lightweight engine. swapping an engine would definitely give me more power but i just dont feel like messing with it to be honest
1 - 11 of 11 Posts
