1 - 3 of 3 Posts
I just had my ball joints replaced and the mechanic who worked on it said nothing was bent, but my tires still bow out (toe out). I was just wondering if anyone had an idea of what could be wrong. thanks.
take it to a shop that does alinements to have it checked, if your truck is a 4x4 don't go to pepboys or one of those, make sure it is a shop that knows and does 4x4's. Good luck.
RE:toe
As mentoined before have your truck taken in for an alignment.Also Ball joints do not usually affect toe were you can phisically see the tire out, that would more than likely be a tie rod(loose or out of adjustment) or a bent part.
Good luck.
1 - 3 of 3 Posts
