What's the max tire width you can mount safetly on a rim according to rim width? I'm assumming you shouldn't mount a tire that is more than 5" wider that the rim, but this is just a guess.
I'm running a 12.5" wide tire on a 8" rim which I know is fine. I've seen some guys running 12.5's on 6" rims before (on the Skyjacker site and ebay). Is that safe?
I'm toying with the idea of a dually with 11" wide tires on the stock 6" wide rims (atleast I think dually's have 6" wide rims, that's what I've read).
Built Not Bought
Its safe. People run 19" wide Swampers on 10 wide rims. May get some funny wear. Big plus for running wide tires on a narrower rim is that its very hard to loose the bead when aired down.
Bushwacker!
your tires will wear funny if on a narrow wheel.
mike
So what do you guys think is the widest tire you can run on a 6" wide rim without excessive wear? This would be on a daily driver, not a dedicated trail rig.
Is a 12.5 on a 6" rim a bad idea, or should I go with a 11" wide tire?
I had a K5 blazer with 33 12.5's on 6" wide rims and it was ok. I did not have any wear issues, but only drove it that way for about a year and the tires were a road friendly AT tread.
