I have a 2007 Dodge Ram 1500 Big Horn with the 20 inch wheel and tires and plan on pulling a 7000lb travel trailer with it.I have read that the 20 inch wheels reduce the towing capacity by 1000lbs which would put me at 7500lbs.I have read this is not due to the size of the tire effecting the gear ratio but is due to the sidewall of the Goodyear HP which is rated at standard load.I looked at buying 17 inch wheels and tire but the pricing was around $1800,instead I was talked into a 275/60/20 ProComp Extreme Mud Terrain(great looking tire) tire with a tow rating of E which I was told would put me back to the 8500lb tow rating.Do you believe this was the right thing to do and has anyone had any problems towing with 20 inch wheels?
