hi, newbie here
anyone know if the factory 275/60/20 tires off the ram will work on the durango without rubbing or do you need to go with a smaller profile like 55's
i would like to keep the 60 profile if i can
thanks in advance for any help
Dante
They work fine!
I have the Ram wheels & 275 60R 20s on my 2005 & they look & work
great. I raised my front torsion bars 5 turns to level the D but
the tires will be ok even if you keep the original settings. Good Luck!! :gr_patrio
My 275/60/20s have rubbed on the drivers side. There are witness marks inside the plactic wheel well liner. I have not played with the torsion bars at all. When it is time to change the tires (bought the wheels/tires used on ebay) I will probably move to the 55s.
You should be fine with 275/60-R20 ... my 285/50-R20's don't come anywhere close to rubbing, and your tire isn't much taller.
