1 - 3 of 3 Posts
Hi new here I have a 2007 dodge ram 1500 with a 4.7 engine. I had to replace the head gaskets (motor had a 103000 miles) when I was removing the cam gears the cams spun. I decided to buy a brand new timing set from everything I have read I line up the tdc marks on balancer and block. Then have primary gears marked at 12 o'clock and 6 o'clock beind the timing cover. Then when placing timing chains on cam gears turn cams counter clockwise so the v8 marks are at 12 o'clock. Is this the right way of doing this
1 - 3 of 3 Posts
