1 - 3 of 3 Posts
where is the temp senso on an 88 1 ton van with a 360. im trying to time this van and need to know the correct procedure. book says to disconnect the coolant temp senso on the thermostat housing. theres so much stuff inthe way i cant see a temp sensor. there looks to be some vacuum switches. Is one of these switches the sensor. book says the spec for timing is 10 advance. is this correct
Discussion Starter · #2 ·
81 thru 83 models show to disconnect the vacuum advance. the one for the 88 model says to disconnect the temp sensor that i cant find. mine has a vacuum advance
Do It In A Van
It should be right next to the thermostat housing. Should be a 2-wire connector.
1 - 3 of 3 Posts
