ok, mabe someone has the same problem....
after driving and coming to a stop at a light, on acceleration there is a single "thump" felt through the vehicle. it's not a back and forth thump, like something is moving back and forth, just a "thump" feeling.
we tried shocks, u-joints, front driveshaft slip joint. cleaned out the splines of the rear drive shaft yoke and lubricated there. replaced the front upper ball joints, and tightened everything we could find. even if it did'nt look loose.
i used to work for nissan and we had a problem with the pathfinders. same feeling. it turned out to be the rear driveshaft splines binding on the transfer case output shaft. cleaning and lubrication helped there, but not on my D.
any ideas??
any ideas??
