What are some things that i could put into my Dakota that would make it go faster, perform better etc. Any suggestions would be greatly appriceated. I have a 1999 Dodge Dakota Sport V6 4X4 Extended Cab.
Thanks!
Thanks!
+1. Even if you do a CAI, a full exhaust system (headers, pipe, high flow cat, muffler), cams, and tune the engine you're looking at maybe 25-30hp, if that... most of the power in the engine comes from the internal design of the engine itself... valve size, compression, cylinder head flow, and cylinder head layout. You can add power to a point, but it's often faster and simpler just to swap in something that will fit easily that is designed with more power in mind from the start. In the case of these trucks it's a V8. You'll get more power with that swap than doing all those mods, and then you can do those to the V8 for even more power.That's definitely the easiest way to get instant horsepower.
Better be careful & not go TOO big on the exhaust size, ANYTHING over 2.5 will hurt low end!! LOTS of people make that mistake with the 3.9 just for the sound, not even realizing the truck is actually SLOWER!!! Same thing with that intake, it was modified for "supercharger" use!!!!yea i plan on puttind dual air intakes into it soon and a new exhaust kit after christmas. im turning it into duals. i cant wait
