The patient is a 95 ram sport 2 wheel drive, 318 with a manual transmission.
The truck is running very poorly, skipping like its running on 7 cyl. It's been at the shop for a day (scanned) and numerous parts replaced. (o2,plugs, wires, rotor, coil, EGR valve) Still no change. Compression checked, ok. When you pull the wires or unplug the injectors it seems to keep running almost unchanged until you get down to two cylinders. (I know that sounds crazy) Scanner was showing a lean condition. (generally)
Anyway, the finger is now pointed at the ECM, and I would like to test it some way before I keep throwing parts at it.
Any help/ideas?? Thanks
