1 - 2 of 2 Posts
For the last few days I have noticed a faint coolant smell around the front of my truck, as well as my temp gauge moving up and down a little bit. Looked under the hood everything is dry. Now this morning the temp gauge was reading about 1/4 the whole way to work. Had lots of heat, am I looking at a bad thermostat or something else? Thanks for any help
Site Administrator
It could be. Check your water pump. Make sure it's dry. There is a weep hole in it that will leak when the seals go bad. If it is dry - I'd replace the Tstat.
1 - 2 of 2 Posts
