I just wanted to know the opinions you all have on this product. I usually don't buy Chevron gas, but I was thinking about buying a bottle of Techron to run through the fuel every once in a while. I know that a lot of you like to use seafoam to clear out the engine, but I thought that using some of this stuff might help reduce the buildup. Also, I saw that Chevron also has Pro-Gard line of products. Is this better, or do you reccomend just using the Techron (concentrate plus).
I was thinking that maybe I should just run a tank of Chevron's high test (supposedly it has a higher content of techron), but don't want to "confuse" the computer as I usually run 87.
Oh by the way, the truck 4.7l has less than 10k on it.
Thanks!
Thanks!
