1 - 3 of 3 Posts
I recently had a taillight out…no big deal…. I changed the bulb and that was that. Now about two week later my friend was telling me its out again. So we started looking and the brake light works... but it does not have a running light when you turn on the headlights. Thought maybe it was just the high side of the bulb but that’s not the problem. I tried 3 different ones with the same result. The truck is not throwing any codes. So, does anyone know what it could be??? I had the bed off about a month ago…could a wire be pinched???? Not sure……………
OFFICIAL CHEBBY HATER
probably just the connector. spray some cleaner in there (wd-40) and then scrub with a wire brush. finally put some non corrosive grease in there to keep moisture and debris out.
i got a 02 and had no running lights front or back and it turned out to be the fuse box (power distribution center) was shorted in the circut board under the fuses 250 for the part but i got the guy i bought it from to pay for the part i payed the labor
1 - 3 of 3 Posts
